Used Tapes Per Storage Policy
Hi All,
i´m looking for an simple report wich shows me the used tapes ( Barcode ) per storage policy.
I tried the Tapes used Report:
→ not good because i see a lot of duplicate barcodes for ech backup. I Only need the infoiramtion storage polcy ABC → 10 Tapes with barcodes nothing less and nothing more
Java gui storage information
→ to much informations. also the summary did not show used tapes. here is the only option to generate x reports for x storage policy
so do you have an idear for an simple report ( show used tapes per storage policy :) )
Hi ​@SSchmidt
There is currently no standard Commvault report that provides a straightforward Storage Policy →  Unique Tape Barcode mapping without duplicate entries.
The closest built-in option is the Tape Details report, which includes both Storage Policy and Barcode information. You can filter the available columns based on your specific requirements to display only the information you need.
For a more concise, inventory-style view, we would recommend using either a custom report grouped by Storage Policy with distinct barcodes or a custom SQL report.
Dheeraj
  • Certified Expert
  • August 26, 2026
Hi Thanks for the hint i will check this report in our enviroment
