Using PLAN with subclients scheduled by external schedulers
  • Jul 5, 2024 1:00 PM UTC
  • 134 views
Forum|alt.badge.img+5
I create a plan, and associated it to SAP HANA subclients.
the backup must be scheduled by external scheduler. third party (command line).
as the plan includes also the schedules, how to avoid to have both schedule running, the goal is to disable the schedule on Commvault side.
When using storage policies, no problem, we just create a Storage policy without a plan assoociate to it.
Thanks !
Best answer by Sunil
Quickest way is to disable activity on the default subclient in GUI.
HANA jobs started from HANA studio / commandline will use different subclients (command line) and (logcommand line).
Disabling backup activity of default subclient will skip the Plan schedules and only application backups will run as per your scheduling outside Commvault.
Sunil-
Sunil
Forum|alt.badge.img+16
  • Jul 5, 2024 1:15 PM UTC
Sunil-
Forum|alt.badge.img+13
  • Challenger
  • Jul 5, 2024 3:25 PM UTC
@Amin91 ,
once you created a PLAN, you can delete ALL backup frequencies from it.
This will result in something comparable to a Storage Policy.
if you need to create automatic / scheduled backup frequencies for different subclients and store data to the same PLANs storage rules, you can add a derived plan / sub plan, that converts your first plan into a base plan and only adds schedules to the base plan, but can be assigned to subclients that require scheduled backups.
this leaves the agents backup enabled and might give you more flexibility ?
