using the netx.jar to connect from our jumpbox to our commserves using SSL
  • July 18, 2024
  • 516 views
From a jumpbox, Instead of connecting to each commserve with mremote (RDP) I want to use the netx.jar.
I installed Java Adoptium, all is fine,
According to the documentation I need to open the port 8401 from the jumpbox to the commserves.
443 is already opened and I can access to the CommandCenter
for 80-81 not opened yet Cybersecurity doesn’t allow this.
The Cybersecurity say that I have to use SSL to connect using the netx.jar
Any option to perform that ?
I saw the useful post of @KeyboardUser
Thanks !
  • July 18, 2024
Before I talk with Cybersecurity I need to know how it works exactly :)
I simulate this on my lab
Jumpbox <> Firewall <> Commserve01
Opened only 443 port, I see that it tried to use first the 443 port
then
Boot URL Redirection to HTTP
I then opened 80-81 ports
I don’t see in the firewall any drop packet for port 8401, I don’t opened it for now
here is my java log file
443, 80-81 opened between the jumpbox and the commserve
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Administrator>"C:\Users\Administrator\Desktop\Commvault Commcell Console.lnk"
Initial URL ---https://commserve01:443/console/Timestamp.txt
javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:130)
        at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:378)
        at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:321)
        at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:316)
        at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1318)
        at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(CertificateMessage.java:1195)
        at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(CertificateMessage.java:1138)
        at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:393)
        at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:476)
        at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:447)
        at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:201)
        at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:172)
        at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1506)
        at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1421)
        at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:455)
        at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:426)
        at java.base/sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:586)
        at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:187)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1675)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1599)
        at java.base/java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:531)
        at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:307)
        at netx.jnlp.runtime.Boot.isJarDownloadRequiredBasedOnTimeStamp(Boot.java:543)
        at netx.jnlp.runtime.Boot.run(Boot.java:224)
        at java.base/java.security.AccessController.doPrivileged(AccessController.java:319)
        at netx.jnlp.runtime.Boot.main(Boot.java:202)
        at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
        at java.base/java.lang.reflect.Method.invoke(Method.java:580)
        at netx.jnlp.runtime.Boot13.main(Boot13.java:99)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:388)
        at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:271)
        at java.base/sun.security.validator.Validator.validate(Validator.java:256)
        at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:230)
        at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
        at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1302)
        ... 24 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:148)
        at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:129)
        at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
        at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:383)
        ... 29 more
Status: CONNECT STARTED +(CONNECT STARTED) @ /console/Timestamp.txt
Status: CONNECT DOWNLOAD STARTED +(DOWNLOAD) @ /console/Timestamp.txt
Status: CONNECTING DOWNLOAD STARTED +(CONNECTING) -(CONNECT) @ /console/Timestamp.txt
isCurrent: http://commserve01:80/console/Timestamp.txt = false
ResourceTracker.initializeResource() ContentType:text/plain
ResourceTracker.initializeResource() ContentLength:10
Status: CONNECTED DOWNLOAD STARTED +(CONNECTED) -(CONNECTING) @ /console/Timestamp.txt
Status: DOWNLOADING STARTED +(DOWNLOADING) -(CONNECTED DOWNLOAD) @ /console/Timestamp.txt
ResourceTracker.downloadResource():text/plain
ResourceTracker.resourceSize():10
Status: DOWNLOADED STARTED +(DOWNLOADED) -(DOWNLOADING) @ /console/Timestamp.txt
Completing dowload for C:\Users\Administrator\Commcell_Console\commserve01\Timestamp.txt
Download Completed for C:\Users\Administrator\Commcell_Console\commserve01\Timestamp.txt
Updating Cache Info for C:\Users\Administrator\Commcell_Console\commserve01\Timestamp.txt
Status: CONNECT STARTED +(CONNECT STARTED) @ /console/cvjvmparms.ini
Status: CONNECT DOWNLOAD STARTED +(DOWNLOAD) @ /console/cvjvmparms.ini
Status: CONNECTING DOWNLOAD STARTED +(CONNECTING) -(CONNECT) @ /console/cvjvmparms.ini
isCurrent: http://commserve01:80/console/cvjvmparms.ini = false
ResourceTracker.initializeResource() ContentType:null
ResourceTracker.initializeResource() ContentLength:621
Status: CONNECTED DOWNLOAD STARTED +(CONNECTED) -(CONNECTING) @ /console/cvjvmparms.ini
Status: DOWNLOADING STARTED +(DOWNLOADING) -(CONNECTED DOWNLOAD) @ /console/cvjvmparms.ini
ResourceTracker.downloadResource():null
ResourceTracker.resourceSize():621
Status: DOWNLOADED STARTED +(DOWNLOADED) -(DOWNLOADING) @ /console/cvjvmparms.ini
Completing dowload for C:\Users\Administrator\Commcell_Console\commserve01\cvjvmparms.ini
Download Completed for C:\Users\Administrator\Commcell_Console\commserve01\cvjvmparms.ini
Updating Cache Info for C:\Users\Administrator\Commcell_Console\commserve01\cvjvmparms.ini
java.io.FileNotFoundException:
C:\Users\Administrator\Commcell_Console\commserve01\galaxy.jnlp (The system cannot find the file specified)
        at java.base/java.io.FileInputStream.open0(Native Method)
        at java.base/java.io.FileInputStream.open(FileInputStream.java:213)
        at java.base/java.io.FileInputStream.<init>(FileInputStream.java:152)
        at netx.jnlp.runtime.Boot.launchJarWithoutDownload(Boot.java:602)
        at netx.jnlp.runtime.Boot.run(Boot.java:231)
java.lang.NullPointerException: Cannot invoke "netx.jnlp.JNLPFile.getApplication()" because "jnlpFile" is null
        at netx.jnlp.runtime.Boot.launchJarWithoutDownload(Boot.java:614)
opening the 8401 ports doesn’t help too. It seems this port is not required at this step
1 > 443 is used
2 > 80 is used to download the file
Thanks !
  • July 18, 2024
@Admin Hello, it seems that my last reply is under review by the admin but I don’t understand why  😂
  • July 19, 2024
Crowdstrike ? Should I repost again ?
Alex Deaconu
The post is visible. I am not sure if you need more than 8401 and 443.
https://documentation.commvault.com/v11/essential/port_requirements_for_commvault.html
What is the error message you are seeing when you connect? Have you tried the button to Authenticate with the Command Center, after you inserted your name and the CommServe Host Name?
  • July 19, 2024
Hello Alex, I posted detailed logs yesterday but it seems that my post was not taken into account, and I received a red banner that indicates that my new reply is under review but it doesn’t matter.
Commserve version is 11.32.54
Here I opened  443 and 8401 from client machine where Java Openjdk is installed and the commserve
Initial URL ---https://wsxxxxxx:443/console/Timestamp.txt
        ... 24 more
        ... 29 more
java.net.ConnectException: Connection timed out: connect
        at java.base/sun.nio.ch.Net.connect0(Native Method)
        at java.base/sun.nio.ch.Net.connect(Net.java:589)
        at java.base/sun.nio.ch.Net.connect(Net.java:578)
        at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:583)
        at java.base/java.net.Socket.connect(Socket.java:751)
        at java.base/java.net.Socket.connect(Socket.java:686)
        at java.base/sun.net.NetworkClient.doConnect(NetworkClient.java:183)
        at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:531)
        at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:636)
        at java.base/sun.net.www.http.HttpClient.<init>(HttpClient.java:280)
        at java.base/sun.net.www.http.HttpClient.New(HttpClient.java:386)
        at java.base/sun.net.www.http.HttpClient.New(HttpClient.java:408)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1304)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1237)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1123)
        at java.base/sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:1052)
        at netx.jnlp.cache.ResourceTracker.initializeResource(ResourceTracker.java:770)
        at netx.jnlp.cache.ResourceTracker.processResource(ResourceTracker.java:606)
        at netx.jnlp.cache.ResourceTracker.access$500(ResourceTracker.java:69)
        at netx.jnlp.cache.ResourceTracker$Downloader.downloadResource(ResourceTracker.java:1045)
        at netx.jnlp.cache.ResourceTracker.startThread(ResourceTracker.java:547)
        at netx.jnlp.cache.ResourceTracker.queueResource(ResourceTracker.java:589)
        at netx.jnlp.cache.ResourceTracker.startResource(ResourceTracker.java:520)
        at netx.jnlp.cache.ResourceTracker.wait(ResourceTracker.java:984)
        at netx.jnlp.cache.ResourceTracker.waitForResource(ResourceTracker.java:452)
        at netx.jnlp.cache.ResourceTracker.getInputStream(ResourceTracker.java:398)
        at netx.jnlp.JNLPFile.openURL(JNLPFile.java:193)
        at netx.jnlp.runtime.Boot.isJarDownloadRequiredBasedOnTimeStamp(Boot.java:568)
Status: ERROR +(ERROR) -(CONNECTING DOWNLOAD STARTED) @ /console/Timestamp.txt
netx: Unable to access URL: Connection timed out: connect
It seems that it need http 80 to be opened.
And now
        ... 24 more
        ... 29 more
isCurrent: http://wsxxxxxx:80/console/Timestamp.txt = false
Completing dowload for C:\Users\Administrator\Commcell_Console\wsxxxxxx\Timestamp.txt
Download Completed for C:\Users\Administrator\Commcell_Console\wsxxxxxx\Timestamp.txt
Updating Cache Info for C:\Users\Administrator\Commcell_Console\wsxxxxxx\Timestamp.txt
isCurrent: http://wsxxxxxx:80/console/cvjvmparms.ini = false
Completing dowload for C:\Users\Administrator\Commcell_Console\wsxxxxxx\cvjvmparms.ini
Download Completed for C:\Users\Administrator\Commcell_Console\wsxxxxxx\cvjvmparms.ini
Updating Cache Info for C:\Users\Administrator\Commcell_Console\wsxxxxxx\cvjvmparms.ini
And now
I can try to login
based on the firewall logs, the 8401 port is used only at this step but I still can’t login
if I click on OK or Login with Command Center I have this error message
