Vault tracker policy action stuck in running state
  • October 18, 2022
  • 203 views
Forum|alt.badge.img+18
Hi all,
we have successfully set up a Vault Tracker Policy and there are a couple of tapes to be exported in view media review.
However, if I click on run now and check Actions under VaultTracker option, I can see the action with the running status but nothing is being done next.
Do you have any idea what I am missing? Of course, we have marked Auto Acknowledge under Vault Tracker Policy Properties. Is there any log or additional settings which needs to be adjusted?
Best answer by drPhil
I can sum up this thread.
Basically, in our case, it was necessary to be sure, that there are I/E slots configured on the library and visible in CV console. Regarding importing tapes back to the library, it is important to have checked these settings - "Do periodic mailslot check" as well as "Enable Auto-Discovery of media into default scratch pool" to be sure, that Commvault is aware of any changes in I/E slots.
Cheers!
Hello @drPhil
Vault Tracker operations should be logged in MediaManager.log on the CommServe. Do you see any errors in that log related to VaultTracker?
  • Do you see the tapes being moved into the IE ports of the library?
  • Do you see anything in the “Exports in Progress” section?
Thank you,
Collin
  • Challenger
  • October 25, 2022
Hi @Collin Harper
Thank you for your response. Now, Vault Tracker export policy (export media) is working fine and tapes are sent to the export locations as desired. Unfortunately, I am not aware what I have set up differently. Anyway, Vault Tracker import policy (Due back for reuse) when ran, it is still in running state and tapes stay in the export location. I guess, since all is tested in the virtual environment (vmware workstation), it could be influenced by the presence of virtual tape library… In the MediaManager.log there was nothing  interesting or strange.
  • Challenger
  • December 7, 2022
Cheers!
