VDDK Vulnerability for HyperV(AzureHCI) backups
  • August 19, 2025
  • 9 replies
  • 168 views
Hi Expert Team,
We are getting below Vulnerability for Nexus scan on AzureHCI nodes where VSA proxies are installed.
These VSA nodes are used only for HCI VM backups not VMWare.We have earlier raised one case 240809-322, but it was specific to VMware.
Now the question is how these plugins loaded when we are not doing VMware backups using this proxy.Can it be deleted manually? If deleted will it have any impact on HCI VM backups?
Plugin Name:
SQLite < 3.50.2 Memory Corruption
libcurl 7.9.1 < 8.4.0 Cookie Injection
libcurl 7.69 < 8.4.0 Heap Buffer Overflow
libcurl 7.32.0 < 8.9.1 DoS (CVE-2024-7264)
Plugin Output:
  Path              : C:\Program Files\Commvault\ContentStore\Base\VMWARE\VDDK\VDDK801\bin\libcurl.dll
  Installed version : 7.84.0.0
  Fixed version     : 8.9.1
  Path              : C:\Program Files\Commvault\ContentStore\Base\VMWARE\VDDK\VDDK800\bin\libcurl.dll
  Installed version : 7.82.0.0
Plugin Output:
  Path              : C:\Program Files\Commvault\ContentStore\Base\VMWARE\VDDK\VDDK803\bin\libcurl.dll
  Installed version : 8.5.0.0
  Path              : C:\Program Files\Commvault\ContentStore\Base\VMWARE\VDDK\VDDK702\bin\libcurl.dll
  Installed version : 7.72.0.0
FYR:
https://documentation.commvault.com/2023e/expert/vddk_support_for_virtual_server_agent_with_vmware_01.html
Best answer by Erase4ndReuseMedia
250804-86
Jon Vengust
  • August 20, 2025
Hi ​@AbdulIkram
Regarding CVE-2024-7264, we do have a public security advisory available:https://documentation.commvault.com/securityadvisories/CV_2024_08_2.html
Regarding the other vulnerabilities, please specify which version of Commvault you’re currently running. A few of these have been patched already. For example, the heap buffer overflow vulnerability fix is available in 11.32.31 and onwards.
  • August 20, 2025
Thank you for looking into this. We are on 11.32.106.
Rajiv
  • August 20, 2025
Hi ​@AbdulIkram can you confirm the access nodes are also running on 11.32.106?
Best,
Rajiv Singal
  • August 21, 2025
Yes complete environment is on 11.32.106.Since we are in hurry, CV case is raised 250820-179.
Erase4ndReuseMedia
You will need to manually clean up the VDDK folders.
The recommendation is to Stop the Commvault Services, and delete the vulnerable VDDK folders.
  • August 24, 2025
We tested it by deleting in UAT environment and it does not impact hyperv backups.However we are waiting for commvault to give goahead on the case to delete in production.
Erase4ndReuseMedia
Fair, we did the same.
Support assured us that VDDK wasn’t required on Hyper-V Access Nodes.
  • August 25, 2025
@Erase4ndReuseMedia  thank you.I appreciate if you can you share the case number if handy?
Erase4ndReuseMedia
250804-86
