VM Validation - Reporting / Notification
  • July 19, 2023
  • 262 views
I’m currently testing the automatic VM Validation Feature and so far it looks good.
The only thing I’m wondering is if there’s an option to send a mail/report with the results of the validation.
Since we could use this to automate VM Backup validations and as some “evidence” for auditing purposes, this would be incredibly helpful.
In the Job Details in the Command Center it shows the different phases and whether or not it was successful, but I don’t want to have to check manually.
Is that possible?
Best answer by Tanuj Balani
Hello @ChrisK
Good Day!
You may try below steps and see if that helps.
1. Log in to the Command Center and hit Dashboard
2. Clicked on the Overview Dashboard drop-down menu and changed that to Virtualization Dashboard
3. Clicked on Validation Failed
4. Check the Backup Validated VMs on the dashboard. Hit More actions and schedule that. Technically it is not an additional report that can be imported. It is a built-in dashboard list that can be scheduled for customer convenience.
Ref Doc - https://documentation.commvault.com/2022e/essential/117325_monitoring_validation_status_for_vmware_vms.html
Hi @ChrisK ,
You can add an Alert:
https://documentation.commvault.com/11.28/expert/5196_alerts_and_notifications_overview.html
Sebastien Merluzzi
Forum|alt.badge.img+5
  • July 19, 2023
Hello @ChrisK
Good Day!
  • Certified Expert
  • July 19, 2023
Thank you @Tanuj Balani the Dashboard looks promising, I’ll play around with that a little.
