VMInstance
  • June 5, 2023
  • 107 views
Forum|alt.badge.img+13
i have create a new client to backup my AD. The DC is a virtual machine on vSphere.
I have installed the AD agent and file agent.
I see there a VMInstance:
What is that? On my old DCs (also VMs) i see this:
When i release the license or delete the VMIntance the next day it is back.
Regards
Dennis
Best answer by Sebastien Merluzzi
@Dennis ,
It is the same Backup.
From vCenter you will see the Child Job, in job details > Virtual Machine Status
You will see the VM Job ID.
From the VM you will see the Parent job, in job details > Description
You will see Job started by job ID.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • June 5, 2023
Hi Dennis,
It seems you have a Hypervisor configured with v2 indexing.
This hypervisor instance config is processing the VM during a backup.
https://documentation.commvault.com/2022e/expert/102122_virtual_machine_clients_and_instances.html
If this is not a wanted outcome you should be able to prevent this by filtering the VM on the hypervisor config in Commvault.
  • June 6, 2023
What do you mean with…...
Is this a new feature? In my older VM clients i have only “Active Directory” and “File System”.
I have configured a virtualisation client:
Do i backup the machine 2 x ??
Because when i go to the VMInstance in my backup history i see backups:
Or are these the backups of the actual virtualisation client?
  • June 22, 2023
is it not possible to deactivate the VMInstance?
Because actually i backup the client twice.
Once over the VMInstance and the other one over my virtualisation client…..
@Dennis ,
