VMware VM backups with Virtual RDMs
PedroRocha
Byte
Hello!
I am running VMware VM backups via SAN transport mode. Several of the VMs have virtual RDMs.
I would like to exclude them from the VSA backup and run them via FS iDA inside the VM.
How to achieve that?
Pedro
Best answer by Emils
HI @PedroRocha
You should be able to achieve this using filters to filter them out
Emils
  • 149 replies
  • June 1, 2023
HI @PedroRocha
PedroRocha
Byte
  • Byte
  • 80 replies
  • June 1, 2023
Disk filters is the way. I only wish there was a way to specify all virtual RDMs for all VMs in an easy way, without having to manually selecting each RDM (consider there is no name pattern, or SCSI name,)
Forum|alt.badge.img+23
Technically, if you do nothing the VM should still be protected except for the RDM disks. On feature release 11.23+ the job completes normally but should print a warning in the events about it.
https://documentation.commvault.com/additionalsetting/details?name=%22IgnoreUnsupportedDisks%22&id=1318
If you want to filter out the entire VM, you could use a tag on them in vCenter and use a filter rule to exclude VMs with a specific tag
PedroRocha
Byte
  • Byte
  • 80 replies
  • June 1, 2023
From the docs I see that the virtual RDMs are protected by default, is that right?
"Virtual RDMs are protected by both streaming and IntelliSnap backup jobs."
https://documentation.commvault.com/2022e/expert/32585_frequently_asked_questions_for_virtual_server_agent_with_vmware.html
I wish I could filter them out just making a filter where I specify: "filter virtual RDMs"
Cookie policy
Cookie settings
