VSAN / XRAIL integration
  • April 17, 2022
  • 775 views
Hello;
I just need to know more about the integration between Commvault and VXRAIL requirements [Ports, Connectivity] also need to know how the backup works and how the traffic goes using normal backup and IntelliSnap.
thanks
Best answer by Scott Moseman
@Jos Meijer  thanks alot , actually i need to know the backup traffic path [data path] if applicable in case of normal backup or intellisnap backup..
The backup data will flow from the VxRail to your MAs over the LAN.  You can use either NBD or HotAdd modes.  SAN mode is not available.  You can use IntelliSnap, but realize you don’t get the same benefits as taking snapshots using a traditional storage array.  The Backup Copy jobs will still send data over the LAN since SAN mode is not available.
Scott
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • April 17, 2022
  • April 17, 2022
@Nezar , can you clarify what you are looking for?
@Nezar , following up on this one.  Can you clarify what you need?
Scott Moseman
Forum|alt.badge.img+23
Scott
