Warning Could not save network configuration. Transit Gateway tgw-0783e3f3a72b93ff1 was deleted or does not exist."
  • January 26, 2024
  • 232 views
HI,
after updating to rel 11.32.35, I receive this warning:
"Failure Reason:srv-access01 Warning A VPC endpoint is not in use for the EBS service. For optimal EBS direct performance, configure a VPC endpoint for the EBS service in account: 605181552103, vpc: vpc-63f86e03., srv-access031 Warning Could not save network configuration. Transit Gateway tgw-0783e3f3a72b93ff5 was deleted or does not exist."
What remains to be changed to eliminate the warning, in addition to having applied the changes to the policy on AWS for the IAM user (CMVAdmin) as suggested by (https://documentation.commvault.com/v11/essential/requirements_and_usage_for_aws_iam_policies_and_permissions.html) because the Transit Gateway tgw-0783e3f3a72b93ff5 exists and is operational.
Thanks in advance
  • January 26, 2024
while backing up a subclient of an AWS VSA...
