Webconsole fails to start and is no longer accessible
  • March 13, 2025
  • 308 views
Hello Community,
After upgrading from version 11.32.81 to 11.32.89, the WebConsole is no longer accessible.
I see the following error messages in the log:
 1 03/13 11:05:11     WARN  ServerBroker:?:? - Invalid response returned: 500
  1 03/13 11:05:11     ERROR DefaultHandler:?:? - Web Service error: web service returned an unexpected response
 commvault.web.core.net.ServerException: INTERNAL_SERVER_ERROR
1 03/13 10:49:33     ERROR LogbackConfigBase:?:? - Error while reading properties from global params (no similar errors will be logged unless the issue recurs after a successful read)
Wrapped by: java.lang.Exception: Failed to retrieve global configuration properties using global params API
Does anyone have an idea what the problem could be?
Hello ​@fjs63
Thanks for the question!
Version 89 had a large amount of webserver vulnerability fix’s included in it.
https://statics.teams.cdn.office.net/evergreen-assets/safelinks/1/atp-safelinks.html
I would guess a IIS reset is needed and if that does not work a reboot would be the next step.
If this does not resolve your issue i recommend a support ticket as there may be other issues that will require a support investigation to identify.
Kind regards
Albert Williams
  • March 14, 2025
Hello ​@Albert Williams ,
thanks for your answer. Unfortunately an iis reset and reboot did not work.
We have now opened a support ticket.
Kind regards
Franz-Josef
Hello ​@fjs63
Please update this thread if you get a simple answer from Support.
Kind regards
Albert Williams
  • March 17, 2025
The problem was an error in the monthly Windows update.
A repair of the .Net Framework fixed the error.
The Web Console is now available again.
The ticket can be closed.
Thank you for your help.
Kind Regards
Franz-Josef Schulten
