Webhook URL not able to configure.
  • July 1, 2026
  • 65 views
We trying to configure webhook in commvault but it not able to configure, getting errror message “Invalid URL specified”
Commvault is not accepting HTTP using HTPS but still failing. Please help
Logs
Machine : Commserver
File    : WebServer.log
5172  102   07/01 15:05:33 ### admin API - Tid:c69a82a76864123c3e345a268fdd6bcb STARTED  POST [/Webhook] Console[AdminConsole] IP[10.xxx.xx.xxx]
5172  102   07/01 15:05:33 ### admin CreateWebhook - Tid:c69a82a76864123c3e345a268fdd6bcb Error while encrypting string:
5172  102   07/01 15:05:33 ### admin IsIPValid - Tid:c69a82a76864123c3e345a268fdd6bcb Sitelocalurl/LinkLocalUrl is provided
5172  102   07/01 15:05:33 ### admin IsValidUrl - Tid:c69a82a76864123c3e345a268fdd6bcb Invalid ip 10.xxx.xx.xxx
5172  102   07/01 15:05:33 ### admin CreateWebhook - Tid:c69a82a76864123c3e345a268fdd6bcb Invalid url specified: https://10.xxx.xx.xxx:9000/receive
5172  102   07/01 15:05:33 ### admin CreateWebhook - Tid:c69a82a76864123c3e345a268fdd6bcb request handling interrupted : ['CV.WebServer.Handlers.HandlerException: Invalid url specified
   at CV.WebServer.Handlers.WebhookHandler.CreateWebhook(CreateWebhook request)
   at CV.WebServer.Controllers.AlertController.CreateWebhook(CreateWebhook webhookCreateReq)
   at lambda_method5207(Closure, Object, Object[])
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Logged|12_1(ControllerActionInvoker invoker)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
   at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
--- End of stack trace from previous location ---
   at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextExceptionFilterAsync>g__Awaited|26_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)'].Response status code set to [403]
5172  102   07/01 15:05:33 ### admin API - Tid:c69a82a76864123c3e345a268fdd6bcb FINISHED POST [/Webhook] [54 ms] HTTP[Forbidden] IP[10.xxx.xx.xxx]
5172  86    07/01 15:06:42 ### admin API - Tid:b7b6462e822fb7d62f144418d2751919 STARTED  GET [/Stream/TraceId/c69a82a76864123c3e345a268fdd6bcb/Logs] Console[AdminConsole] IP[10.xxx.xx.xxx]
File    : CommandCenter.log
7688 8 07/01 15:05:32 c69a82a76864123c3e345a268fdd6bcb 10.xxx.xx.xxx 4  INFO  ProxyController:handleReq:189 - Request received for API: Webhook
7688 8 07/01 15:05:33 c69a82a76864123c3e345a268fdd6bcb 10.xxx.xx.xxx 4  ERROR PlainHttpHelper:getResponse:576 - ******Error code 403 returned for API:[http://10.xxx.xx.xxx:81/SearchSvc/CVWebService.svc/Webhook] URL:http://10.xxx.xx.xxx:81/SearchSvc/CVWebService.svc/Webhook
7688 8 07/01 15:05:33 c69a82a76864123c3e345a268fdd6bcb 10.xxx.xx.xxx 4  INFO  ProxyController:handleReq:350 - Response received (Status:403) for http://10.xxx.xx.xxx:81/SearchSvc/CVWebService.svc/Webhook.
7688 5 07/01 15:06:42 b7b6462e822fb7d62f144418d2751919 10.xxx.xx.xxx 4  INFO  ProxyController:handleReq:189 - Request received for API: /Stream/TraceId/c69a82a76864123c3e345a268fdd6bcb/Logs
File    : CVEntityCache.log
5172  102   07/01 15:05:33 ### admin ProcessGETEntityReq - Tid:c69a82a76864123c3e345a268fdd6bcb [GetUserCompanyIdByUserId] Completed [regular] request with status [SUCCESS]. user:[1]; localeId:[0]; entity:[USER]; total records:[1]; Time Elapsed:[1 ms]
5172  102   07/01 15:05:33 ### admin ProcessGETEntityReq - Tid:c69a82a76864123c3e345a268fdd6bcb [GetUserGroups] Completed [regular] request with status [SUCCESS]. user:[4]; localeId:[0]; entity:[USER]; total records:[1]; Time Elapsed:[11 ms]
File    : CCBrowser.log
7688 1 07/01 15:06:42 10.xxx.xx.xxx  INFO  ErrorHandlingController:handleConsoleError:43 -
Cannot read properties of undefined (reading 'feedsList')
TypeError
https://10.xxx.xx.xxx/commandcenter/#/logsForTraceId/c69a82a76864123c3e345a268fdd6bcb
[] 14629 H.current null https://10.xxx.xx.xxx/commandcenter/dist-cc/coreApp/ccApp/ccApp.js?_1777302605032
[] 12283 ? null https://10.xxx.xx.xxx/commandcenter/dist-cc/coreApp/ccApp/ccApp.js?_1777302605032
[] 52531 ? null https://10.xxx.xx.xxx/commandcenter/dist-cc/coreApp/ccApp/ccApp.js?_1777302605032
[] null Array.forEach null <anonymous>
[] 52519 S.B.onMessage null https://10.xxx.xx.xxx/commandcenter/dist-cc/coreApp/ccApp/ccApp.js?_1777302605032
[] 34644 qn null https://10.xxx.xx.xxx/commandcenter/dist-cc/vendors/vendors-d8eee3b64df2dae3b3e9.js
[] 34500 Sn null https://10.xxx.xx.xxx/commandcenter/dist-cc/vendors/vendors-d8eee3b64df2dae3b3e9.js
[] 36678 dn null https://10.xxx.xx.xxx/commandcenter/dist-cc/vendors/vendors-d8eee3b64df2dae3b3e9.js
[] 16608 Te.x.onmessage null https://10.xxx.xx.xxx/commandcenter/dist-cc/vendors/vendors-d8eee3b64df2dae3b3e9.js
Mohammed Ramadan
Hi ​@SureshPS
the webhook URL configured public HTTPS endpoint with valid public CA ?  and what CS version you are use ?
Thanks ,
Ramadan
  • July 7, 2026
Hi Ramadan,
Its self-signed certificate. CV version - 11.42.90.
Both server communication is working, tested using cvping, curl command. I hope in application level somewhere its blocking. Have added additional setting for whitelisting also
Suresh
