Webhook URL - Offline
  • July 28, 2022
  • 510 views
Hi
I have a CV alert that sends notifications to MS Teams via a webhook and it works fine (has been for months).
I have now duplicated the alert but pointing the notification to a different teams channel with a different webhook. The problem is that the CV webconsole says the second webhook URL is offline.
Hover over the webhook and I get > “Offline (28/07/2022 15:25:31)”
I know the webhook URL works as its used by grafana successfully and also calling from the terminal works:
curl -H 'Content-Type: application/json' -d '{"text": "Hello World"}'  [WEBHHOOK_URL]
Any ideas why CV would report it offline?
Mike
Best answer by Mike Gale
@Mike Struening  - No we didn’t get it working.  But the project was put on hold temporarily. It is likely that I will come back to look at this over the next few weeks
@Mike Gale , that’s an interesting one.  I’ll loop in some developers for their feedback.  To confirm, it fails to work, period?  Or does it just erroneously sohw as offline (but still function)?
  • July 28, 2022
@Mike Struening
Yeah it wont work at all I can’t get alerts triggering to the new webhook / teams channel.
One avenue I’m investigating is my CV authentication method is SAML and the the other webhook looks to have been set up with AD.
Keep me posted on that angle.
I have inquired with some devs to get a reply here as well!
@Mike Gale , following up on this one.  Were you able to get any answers on your side?
  • August 26, 2022
Sounds good, @Mike Gale !
