what is cvfandmsvc process ?
  • June 1, 2026
  • 121 views
Forum|alt.badge.img+13
Hi Team,
we found a process named CvFanDmSVC installed and running in commvault base directory, but we couldn’ t find any information about this process. This process ran even though the backup wasn't running. Why does it run, and what is its purpose?
CvFanDmSvc
Properties and tags
Main technology
Other
Bitness
64-bit
Command line args
/opt/agents/commvault/Base/CvFanDmSvc
EXE name
CvFanDmSvc
EXE path
/opt/agents/commvault/Base64/CvFanDmSvc
Ports
Sureshkumar S
Hi ​@0ber0n ,
Good day!
There will be multiple executable present under base folder once you install File system agent.
is this process causing any issue or you are just interested to know what it does?
Sureshkumar S
  • June 2, 2026
Hi ​@Sureshkumar S
We are conducting an investigation and observed that this process was running. During that time, the process was showing the highest CPU usage, so our Security Teams want to know what the process does and why it's running.
  • June 5, 2026
Hi ​@0ber0n
CvFanDmSvc is Commvault’s Linux fanotify-based file data management / stub recall service. This will be part of default FS install. It is expected to use resources during backup/Archive or recalls. If you see any abnormality and impacting server performance, please ensure the data backup/archive operation is scheduled during less busier time. If needing further analysis, please open a ticket with us for deep dive.
