What is ..\iDataAgent\JobResults\DM2CacheDir\EdgeCollect used for?
  • July 12, 2024
  • 143 views
On one of our media agents I came accross a folder named  ..\iDataAgent\JobResults\DM2CacheDir\EdgeCollect
It did not contain any data, but tens of thousands of empty subfolders. At first I thought it might be related to Threat Analysis, but that software package is not installed. I renamed the folder, and it got recreated again.
The media agent had the index server roles Data Analytics, EDGE drive, and FileSystem Index assigned. I removed EDGE drive, and renamed the EdgeCollect folder, but it was recreated again.
What’s the purpose of this folder, and which process/functionality is using it?
  • July 15, 2024
We might need a case raised so we can identify the exact configuration to better understand what product feature is creating it - so you can take a well-informed approach.
  • July 17, 2024
Thanks for your reply @mfox . I opened a support case and hope to get a conclusive answer.
