What is the difference between software WORM and hardware WORM
  • July 3, 2023
  • 263 views
We are unable to see the option for WORM on CommCell console in Commvault 11.30. According to new releases what exactly is the difference.
Best answer by Sebastien Merluzzi
Hi @Lahari ,
You see them here:
https://documentation.commvault.com/2023/expert/14083_copy_properties_general.html
Storagehttps://documentation.commvault.com/2023/expert/9251_configuring_worm_storage_mode_on_cloud_storage.html
Softwarehttps://documentation.commvault.com/2023/expert/157455_locking_retention_and_deletions_with_compliance_lock.html
Sebastien Merluzzi
Nikos.Kyrm
  • Community All Star
  • December 27, 2023
Hello @Sebastien Merluzzi
In order to enable WORM Storage Lock in a Azure Blob Storage, must be also enable immutability from Azure side?
Also, Commvaul’t WORM Storage Lock, can prevent Azure Storage account from deletion? (also from Azure side)
Thank you in advance,
Nikos
