what protocol that Commvault use for exchange online
  • October 18, 2022
  • 315 views
Hello team,
this is regarding to article >  Office 365 Deprecation Notice: Basic Authentication
currently there are couple of basic authentication protocols have been disabled and our customer use basic auth and need to identify to which protocol out of list is Commvault use to backup Exchange online
thanks
Best answer by DanC
I have contacted support advised that EWS is the one that’s leveraged
  • October 18, 2022
Can someone please move this to Category: Commvault Q&A, thanks
  • October 18, 2022
@DanC , glad you were able to get an answer from support!
I’ll move the thread as requested, too.
  • October 25, 2022
@Mike Struening thanks
Basically, we will have to make sure both protocols(EWS and Exchange Online Powershell) get re-enabled in order to run exch online mailbox backup when use basic authentication
We were running into an issue where mailbox backup failed to run with basic auth error :
***CvRTagCreator.log***
0000 0001 10/24 11:41:42 ### $Session = New-PSSession -ConfigurationName "Microsoft.Exchange" -ConnectionUri https://outlook.office365.com/powershell-liveid/ -Credential $Cred -Authentication Basic -AllowRedirection -ErrorAction Stop
0000 0001 10/24 11:41:42 ### Import-PSSession $Session
Connecting to remote server outlook.office365.com failed with the following error message : Access is denied.
Though EWS is enabled,  and turned out that  ‘Exchange Online Powershell protocol’ was disabled and it prevent CV powershell script from running. so we followed MS doc and submitted a request to re-enable the service/protocol and it took about 30mins to get it done
Then ran manual discover mailbox from proxy server via Powershell with elevated privilege :
PS C:\Program Files\Commvault\ContentStore\Base> .\AdMailboxMonitor.exe -o autodisover -refreshInterval 0 -a 2 -c 7:O365-MBX -cn Exhange_proxy_server_name  -vm Instance001
once it completes, cv was able to discover all mailboxes and backup starts running
https://documentation.commvault.com/2022e/expert/103534_exchange_mailbox_agent_user_mailbox_exchange_online_through_azure_active_directory_environment_port_requirements.html
This link provides the ports.
For Exchange online PowerShell is leveraged to discover users. EWS it for data transfer.
Important note it is recommended to leverage Modern Authentication steps and info listed here:
  • October 25, 2022
@Scott Reynolds  thanks
we will switch to modern auth soon
Meanwhile will need to keep  exch backup continue to run under basic auth
