Will be mounting live volume [] to worker pod [] since it does not support volume snapshots
  • April 3, 2025
  • 8 replies
  • 247 views
downhill
Explorer
I’m starting a new thread for a repeat topic as I don’t see an actual solution in the previous one.
OpenShift bare metal - all native storage - no way to configure snaps (or is there)? I have read and re-read BoL but am missing something if Waldo exists.
Will be mounting live volume [] to worker pod [] since it does not support volume snapshots.  How to ignore this error? Meaning - we know this is probably an issue for Commvault unless someone has cracked it, so, rather than have to think about them each day, is the answer to “Hide this event”? I can say we don’t have any PVC’s yet but I see the risk in muting them entirely if indeed that means PVCs aren’t protected properly.
This is on 11.36.41 BTW.
thanks
Onno van den Berg
Forum|alt.badge.img+24
@Sougato Roy can you raise this question towards ​@AmitM
Sougato Roy
  • April 4, 2025
Hi Onno,
Thank you and It was good to hear from you. I'll follow up with you as soon as I have an update.
Roy
Manoranjan Reddy
Hi Onno
In absence of CSI Snapshot capability on Kubernetes, we mount the application PVC (live volume) to worker pod and read data from it, that's when you see below logging.
503419 7aefc 04/03 23:37:16 23279 K8sApp::AddVolumeToPod() - Will be mounting live volume [nginx-pvc-1] to worker pod [nginx-pvc-1-liv-vol-cv-23279] since it does not support volume snapshots
With CSI, we take a snapshot of the PVC, Create PVC from snapshot and then mount that PVC to worker pod and read from it.
Manoranjan
downhill
Explorer
  • April 4, 2025
Hi guys,
I was hoping that bK8sSnapFallBackLiveBkp would mute the events but it doesn’t. I also know we don’t have any PVCs as of yet in these clusters so it isn’t even a factor. In fact with bare metal OpenShift there is no CSI - this is all “local” NFS each node provides (ODF I believe).
Do you guys believe that “hiding” the 72:106 events is wise and are you saying that without any CSI in play there is no snapshot capability? Sorry I’m not a K8s guy, just trying to understand whether this is something I need to spend time on with our SME.
thanks
Manoranjan Reddy
Snapshot capability comes with CSI, so no CSI implies no snapshot capability.
Without snapshots, achieving application-consistent backups is challenging because applications may be writing to the PVC during the backup process, hence the message is logged as a reminder.
downhill
Explorer
  • April 4, 2025
Yep, understood. But these are etcd and generic namespace backup jobs (for now). So we think ignoring the events is OK?
thanks
Manoranjan Reddy
These log messages are intended to caution users about the absence of snapshot capabilities in the Kubernetes cluster and the potential lack of application-consistent backups.
They can be safely ignored if application consistency is not a requirement/concern.
Onno van den Berg
The question here, from customers, is if there is a possibility to silence the warnings. The warnings our now flooding the event viewer, especially on scale, with events who cannot be solved due to known constraints. Is there an additional setting that we can set to stop it from being generated?
