Work completed with one or more errors when recovering from VMWare to AWS EC2 CLOUD.
During V2C (VMware to AWS EC2 Cloud) recovery, the recovery operation was completed, but the operation was terminated due to Complete one/error.
Then, when you access AWS, the guest is created normally, but the validation fails and the guest is not running
The target client is Windows 2019std, and the Commserve version is V11 SP36.
The proxy server is V11 SP32.
Hello ​@james.lee
Completed with one or more errors and completed with one more more warnings can be very misleading status codes and gets the best of us all,
If you attempt to restore 1000 files, and 1 is successful and 999 fail you will have a job that completed with one or more errors. There are thresholds that can be configured to mark a job as failed based on items and such but sometimes that can really throw you astray.
With this in mind do you have more details around the error, what it reports was successfully restored or any further details to go on? if you think this issue is related to your environment and possible a configuration issue a support ticket might find you a faster resolution. Happy to help in anyway if you can provide further context and details.
Kind regards
Albert Williams
Except for V2C
We have proceeded with the original purpose, P2C, but the operation fails with that message.
