Workflow getprocessauthorization Default timeout for authorization
  • February 10, 2023
  • 166 views
EricF
Forum|alt.badge.img+5
Trying to determine the timeout auth under the workflow properties. Under timeout for authorization it says default 10. Is that seconds\minutes\days?
It was set for 1 as a test and we ran a delete, approval workflow for a backup job but it set in the job controller for over an hour before we just approved it.
Best answer by Gseibak
EricF - default is 10 days
//If timeout is not set in configuration, set default timeout as 10 days and converting it to minutes//
  • February 10, 2023
Forum|alt.badge.img+8
  • February 14, 2023
 @Gseibak  I had a doubt about these authorization workflows, how are they invoked?
once we deploy, it automatically picks when the task( delete jobs/ restore job) is submitted by a user.
How is Commserve tracking them?
i meant we don’t configure, additional events for these workflow,
we just have to deploy these workflows, and it automatically works..
  • February 14, 2023
that’s correct - these types of workflows are called “Business logic” workflows, meaning we capture the event as it happens and act on that event when we see the specific XML response.
versus a normal workflow where you have to run manually or schedule it, business logic workflows “listen” if you will for specific XML events as soon as you deploy them\..
https://documentation.commvault.com/2022e/essential/131225_creating_business_logic_workflow.html
