Zjištění smazaných zestárlých dat
  • May 12, 2023
  • 32 views
I regularly run the data aging task. How do I find out which specific data has been deleted by this job? I am referring to specific backups and their size. Thank you.
Best answer by Hyder
I don’t think this is possible from a user reporting standpoint yet
You could run a DataAging report daily and compare the day before and after, but thats a lot of work
Hyder
  • May 12, 2023
  • May 15, 2023
Thank you for your reply. Somehow I don't understand why there is no information available on what was deleted. But if that's the case I consider it closed.
