Proper way to shutdown
  • April 23, 2025
  • 160 views
Need to shutdown one end of a livesynch HA setup without screwing up DDB or losing any data.
MA w/DAS bare metal 2U & 2 power store arrays
CS is a bare metal 1U
Total newb question i know. Is my process correct?
shutdown services on MA & CS
get into powervault mgmnt and preform graceful shutdown
shutdown both servers
sbhatia
Forum|alt.badge.img+9
  • April 25, 2025
If you need to shut down one side of a Commvault LiveSync HA setup, here’s the safe way to do it so you don’t mess up the DDB or lose data:
  • First, check if the CommServe you’re shutting down is the active one. If it is, do a planned failover to the standby node.
  • Pause or let any running jobs on the MediaAgent finish, and put the MA in maintenance mode so nothing new starts.
  • Gracefully stop all Commvault services on both the CS and MA.
  • Use the PowerVault/PowerStore management tools to shut down the storage arrays gracefully (make sure there’s no active I/O).
  • Once all that’s done, power off the servers.
Don’t skip the failover or maintenance steps otherwise, you risk DDB or data issues. This order keeps everything clean and safe.
