SSO login Issue for Cross Domain
  • May 5, 2022
  • 8 replies
  • 385 views
Forum|alt.badge.img+2
8332  18a0  05/05 11:06:42 ####### GetFromUsersPropDB() - Enter
8332  18a0  05/05 11:06:42 ####### GetFromUsersPropDB() - Exit
8332  18a0  05/05 11:06:42 ####### ::processAdUser() - Blobsize returned from processSSORequest = [0], dwErr=[0xc000019b]
8332  18a0  05/05 11:06:42 ####### ::processAdUser() - Unexpected return code [0xc000019b] from processSSORequest
8332  18a0  05/05 11:06:42 ####### ::processAdUser() - error not retrieved from formatMessageA(..)
8332  18a0  05/05 11:06:42 ####### EvSecurityMgr::userLogin() - processAdUser returned [-1], "error not retrieved from formatMessageA(..)"
8332  18a0  05/05 11:06:42 ####### EvSecurityMgr::userLogin() - Socket [0x0000000000004028]: Database error [-1/].
8332  18a0  05/05 11:06:42 ####### ::sendResponse() - FAILED [DataBase Error.]
8332  18a0  05/05 11:06:42 ####### handleLoginOperations() -  Encrypted Login Failed.Browser Session Id [1005]
8332  6310  05/05 11:06:43 ####### dropConnection() - Socket [0x0000000000004028]: Closing Browser Session id [1005].
8332  59c8  05/05 11:06:43 ####### ::disconnectSocket() - Socket[0x0000000000004028]: Is attempting to exit for [Command Line Interface@ User Aoocunt] on port [8401]
8332  59c8  05/05 11:06:53 ####### ::disconnectSocket() - Socket [16424]: Has exited successfully for [Command Line Interface@Server NAme] on port [8401]
Best answer by Matt Medvedeff
Are you seeing any errors/warnings related to Authentication/Kerberos in the Windows System Event logs?
The error in the logs seems to indicate that Authentication is failing in AD
sure let me check that . Thanks Matt
::processAdUser() - Blobsize returned from processSSORequest = [1498], dwErr=[0x90312]
8332  2868  05/05 16:15:36
EvSecurityMgr::userLogin() - Socket [0x000000000000901C]: Blob Sent to GUI [1498]
Getting above errors now
Please let me know if you are seeing any errors/warnings related to Authentication/Kerberos in the Windows System Event logs when attempting to log in
April
@Matt Medvedeff getting this error now for qlogin
Understood, but we need to confirm that there are no errors in the OS side as SSO passes the credentials to AD for authentication
