Add VMware hypervisor problem
  • May 26, 2024 6:47 AM UTC
  • 81 views
I can not add vmware (vcenter) hypervisor to Commvault. I did upgrade Commvault from 11.32.35 to 11.32.54 (Maintenance Release) and I notice this problem as you can see on the attached picture. I saw that before upgrade (v 11.32.35) I had the same problem.
Hello @Lukasz Jarosz
A deeper dive in the logs to troubleshoot that error is going to be needed.
I had a look over other cases that may have been raised with the same error and i am seeing a couple but nothing that has made its way to Dev.
Please raise the case and report back on this thread if you get the issue resolved. It could be a bug that Dev will need to address.
Kind regards
Albert Williams
