Pre Upgrade check for clients
  • Oct 26, 2026 5:47 PM UTC
  • 7 replies
  • 89 views
I’m trying to get a list of clients which would be a problem when I update to 11.44 from 11.36 and there are multiple clients running 11.24 and older versions.
This document explains what the errors do when I run the test upgrade from the java console but there are no steps documented to explain how to do this.
Troubleshooting Errors Found During a Request an Upgrade or Test Upgrade
How do I get the list of clients which would be an issue when I do the update?
Best answer by Pradeep
Hi ​@Steve_ ,
We have developed a standalone assessment tool that reviews the current configuration and client version to identify deprecated versions or configurations that may impact the upgrade.
The tool runs independently and eliminates the need for CV Media, simplifying the assessment process and helping proactively identify potential upgrade challenges.
The tool is currently being uploaded to the Commvault Store and is expected to be available shortly.
Search for pre upgrade Advisory tool.
In addition to the above, you may also run below SQL query to get the list of clients configured with Sp24.
SELECT
   ac.name,
  cpv.productVersion
FROM
    app_client ac
JOIN
    ClientProductVersionView cpv
ON
    ac.id = cpv.clientId;
https://cloud.commvault.com/commandcenter/#/softwareStore/37144
Hi ​@Steve_
As of now, there is no standalone pre-upgrade check report, it’s currently a built-in report that runs at the beginning of the CommServe upgrade process, if any problems detected, the upgrade would pause, report the issues and their mitigation steps per the document you shared, at this point, you can just stop (cancel) the upgrade and start the services without any impact (except the service stop/start).
We have CMR 574128 (part of larger project 5339) to get this capability in the future, you can check with your account team to add your account to this project request to increase visibility.
The current workaround is to create a client group that detects clients with 11.24 and below or V10 and prior clients so that you can see all of them in one place ~ I agree it’s not ideal.
Adding a Smart Server Group by Using Automatic Association
Abdu
  • Oct 29, 2026 6:14 PM UTC
Hi ​@AbdulRahman AlSindiony ,
Thanks for your answer, will check on adding the CCID’s to the CMR.
  • Oct 31, 2026 1:28 AM UTC
Hi ​@Steve_ ,
SELECT
   ac.name,
  cpv.productVersion
FROM
    app_client ac
JOIN
ON
  • Nov 2, 2026 3:01 PM UTC
Thanks ​@Pradeep , could you please confirm when the tool would be made available?
  • Nov 3, 2026 2:06 AM UTC
HI ​@Steve_ ,
We expect the Upgrade Advisory Tool to become generally available within the next few weeks.
In the meantime, you may open a support case with us. Once the case is created, please request the assigned engineer to run the Upgrade Advisory Tool. We can stage the current database, run the tool internally, and share the resulting report with you.
  • Nov 3, 2026 8:21 PM UTC
Hi ​@Pradeep - I raised the case, 261103-867 but I’m being blocked by the FL team from getting this case assigned. Could you please take a look?
  • Nov 4, 2026 1:39 AM UTC
Hi ​@Steve_ ,
I have added an internal note and it should be assigned to engineer to review this further. Mean while kindly upload the current Commserv DB to the case using Send log option.
