Rhel 5 / Centos 5
  • November 26, 2025
  • 88 views
Hi
I am trying to install an FS agent on Centos 5.4.
With an agent V11SP28: I get an error saying ‘could not find any installer to use’.
With a V11SP21 agent: the installation gets stuck: Using update installer Bits/linux-x86/LooseUpdates/CU24/linux-glibc2.3/installer/newinstall.gz:
I don't know if these two agent versions are compatible with Linux 5.
  • November 27, 2025
V11 does not support linux versions that old. You can try install an older agent version (not supported, but should work)
  1. Grab a copy of V10 from here
  2. Allow the install of older versions using these instructions
  3. Try install the v10 agent now
