[32:690]
  • September 13, 2026
  • 24 views
How can Commvault be configured to write backups to tape media? (Note: I have already added the tape and can see the drives and media; I have two drives and three tapes, as well as two backup plans. However, while one plan always succeeds, the second consistently results in errors [32:690] and [32:193].)
Sureshkumar S
 Hi ​@Abbdallah ,
Good day!
Please  perform the following checks for the tape backup failures:
  • Verify that the failing plan is associated with the correct Storage Policy and Tape Copy.
  • Confirm the Data Path is enabled and points to the expected MediaAgent and tape library.
  • Ensure both tape drives are online and available for allocation.
  • Verify that the tapes are writable, not marked as full/bad, and that sufficient media is available in the scratch pool.
  • Compare the working and failing plans for any differences in Storage Policy, Copy configuration, or MediaAgent assignment.
  • Retry the job and share the complete error message associated with [32:690] and [32:193], along with the Job Details/Event Viewer logs from the failed attempt.
As another plan is successfully writing to tape, we would like to identify any configuration differences specific to the failing plan.
Sureshkumar S
  • September 14, 2026
[32:690] Drive in which Media is mounted is not ready to use.
Sureshkumar S
Hi ​@abbdullah,
  • Check the tape drive status in the CommCell Console; ensure it is online.
  • Reset the affected drive to clear any stuck state.
  • Make sure there are empty slots in the tape library; remove tapes if all slots are full.
  • Clean the tape drive using a cleaning tape and mark it as cleaned in Commvault.
  • Verify network and service status on the MediaAgent.
Sureshkumar S
Thanks bro
