add a FC tape library
  • September 2, 2021
  • 194 views
Forum|alt.badge.img+13
Hello Community !
I am trying to add a tape library HP MSL G3 Series to Commvault.
I am using the Expert Storage Configuration. i have selected the Two Media agents (they are already zone with the tape libraries)
I have followed the procedure. Now it asks if the library have a barcode reader and I don’t know :)
can you help me please ?
Thanks !
Best answer by MichaelCapon
Hi @Bloopa ,
Do you have access to HP “Command View” or other Utilities for the MSL Library? - This may help identify if the library has Barcode Reader hardware.
Michael
MichaelCapon
  • September 2, 2021
Hi @Bloopa ,
Michael
