Add Library Fujitsu LT20 to commserv
  • September 15, 2021
  • 13 replies
  • 102 views
Fernando Souza
Explorer
@Mike Struening
Hello Guys,
for add a new physical(first) library to a CommCell, what´s the best procedure and sequence to add?
The customer need to send the historical data to a physical library(Fujitsu LT20) and generate new Full Backup, and  need to send 3 times (backups full) before erase data.
Best answer by Mike Struening
You can just create Scratch Pools:
https://documentation.commvault.com/commvault/v11/article?p=10188.htm
However, it looks like you installed the LT20 as a Storage Pool and not a Tape Library.
Fernando Souza
Explorer
Why appear three times?
Directy and secondary?
Fernando Souza
Explorer
Can i use deduplication in LT20?
@Fernando Souza , confirming the first question.  The second one regards Dedupe and the LT20 is a tape library, so it’s not listed as an option.
@Fernando Souza , looks like you created a Tape Library Storage Pool, though I think you just wanted to add a Tape Library:
https://documentation.commvault.com/11.24/expert/9636_tape_libraries_getting_started.html
Can you confirm what instructions you followed?
Fernando Souza
Explorer
  • September 16, 2021
Hello @Mike Struening
i would like to create a Pool for each group of tapes.
Exemple:
i will do a backup job to a pool of tapes, then i do another full backup to another tape group.
and put these tapes in the other local.
Fernando Souza
Explorer
I removed  and add again in the Commvault
Found the Library Fujitsu LT20
Rigth click and Configure
Configure tape clean: slot 5
Is it correct?
I think need to create a “Media by Groups”, this is the option to create the pools, example: Pool for File Systems, SQL, Oracle ok?
Fernando Souza
Explorer
@Mike Struening
I select these options to the clean media:
Fernando Souza
Explorer
@Mike Struening
If i create pools, have a problem, because a tape just belong a one pool, correct?
I want to create just one pool.
Fernando Souza
Explorer
@Mike Struening
Another question Mike,
Why this icon is different:
Everything looks right.  You have the right type (Tape Library), you have the cleaning defined, and you should create one pool.
The icon in your last post indicates that’s an aged tape with some content (but the content is all aged).
Fernando Souza
Explorer
  • November 10, 2021
hello @Mike Struening
The, the content is old, how can i remove this content?
