AirGap Workflow and CommServe LiveSync Network Proxy Issue
  • Dec 16, 2025 7:22 AM UTC
  • 129 views
Kamil W
Certified Expert
Hi guys!
I need your help.
I am trying to use AirGap Workflow to set proxy cennection between MediaAgent ‘cvmakrk01’ and CommCell Infrastructure.
I have created following computer groups.
Then I have created the following Networktopology for AirGap workflow.
My goal is to push Commvault to use ‘cvproxy’ client to set tje network connnection between MediaAgent ‘cvmakrk01’ and Commvault infrastructure anf the use AirGap workflow to turn on ‘cvproxy’ only for the time of AuxCopy jobs.
However, I can see, than even if the ‘cvproxy’ is powered off, the Check Readiness still shows me that ‘cvmakrk01’ is ready.
MountPath Validation and AuxCopy job runs as normal.
What is important, I tnink, CommServe LiveSync is configured in my environment, so I can also that ‘makrk01’ uses LiveSync network topology for communication. Probably this is the reason, why ‘cvmakrk01’ is always ready.
Is any way to set the ‘cvmakrk01’ to ignore LiveSync proxy client and use only ‘cvproxy’ client to communication?
Rgds,
Kamil
Moohammed Ramadan
Explorer
Hi ​@Kamil W
Are the Air-gap MA and CS on the same network?
Mohammed Ramadan
Data Protection Engineer
Kamil W
Certified Expert
  • Certified Expert
  • Dec 16, 2025 1:10 PM UTC
There are two locations:
WAW: CS and Proxy
KRK: AirGap MA
There are on different networks but there is a WAN connection between them.
Rgds,
Kamil
