Aix & DataDomain DDBoost over Fiber (SAN)
  • June 2, 2026
  • 8 replies
  • 125 views
How may I know if my Aix environment is supported with DataDomain DDBoost over fiber?
Commvault Version: 11.40 release 22
Commvault Media Agent SO: AIX 7.1/7.2
We have a large Oracle DB with 50Tb that we would like to protect.
  • June 3, 2026
Hi ​@FTenorio,
AIX MediaAgents can be installed and used for basic data movement, but cannot host deduplication (DD) stores—which means they cannot act as the MediaAgent for Data Domain DDBoost libraries (over Fibre Channel or IP).
The  AIX MediaAgents to directly host or manage Data Domain DDBoost libraries is not supported.
For DDBoost integration (including over Fibre Channel), you must use a supported MediaAgent OS such as Linux or Windows (x64), as per the documentation below.
https://documentation.commvault.com/11.40/software/support_for_data_domain_boost_client.html
https://documentation.commvault.com/11.40/software/support_for_data_domain_boost_access.html
Karthik
RubeckDK
Explorer
  • June 3, 2026
Sorry for buggin’ in…. I might be wrong, but the question seems be related to client- direct… Installing the Storage Accelerator and Storage Accelerator Add-ons on the client seems as all there’s needed (unlike in v.11.32 where the Media Agent component is required to be installed). Client writes /ready directly to the DD and backend Media Agents host the meta data (index etc).  So no CVLT dedup will be used in such scenario..
/RubeckDK
  • June 4, 2026
Hi ​@RubeckDK
You got it right.
The client is a Oracle running on Aix and unfortunately our DataDomain only has 1Gbps network to this server. We would like to understand if DDBoost over FC / SAN can be used.
Tks !
FT
  • June 5, 2026
Hi ​@FTenorio,
AIX is not supported as a MediaAgent or Storage Accelerator client for Data Domain DDBoost integration (including over Fibre Channel/SAN) in Commvault 11.40.
Only Linux and Windows (64-bit) MediaAgents are supported for Data Domain DDBoost (Client or Access library), whether using Ethernet or Fibre Channel (FC/SAN) connectivity.
Karthik
  • June 5, 2026
Any chance it may be field supported? Customer is already using DDBoost over IP with Aix and it's working.
  • June 8, 2026
Hi ​@FTenorio ,
Is it using the same storage accelerator package. Because the Storage Accelerator package itself cannot be installed on an AIX client. Storage Accelerator (SA) is only supported on Windows (x64, ARM64), Linux (x64, ARM64, PPC64), and Darwin x64 Unix clients. There is no support for AIX as a platform for the Storage Accelerator package.
https://documentation.commvault.com/11.40/software/accelerating_backups_to_cloud_storage_libraries.html
Karthik
RubeckDK
Explorer
  • June 9, 2026
As ​@kkarthikk mentions the Storage Accelerator package is not supported on AIX..  So maybe the MA component has been installed on your customers AIX clients?
Found an AIX test box and tried it…. The Storage Accelerator package can be installed but will not work..   but installing the MA component seems to do the trick:
Unfortunately I’m unable to test it over Fiber Channel as the DD boxes we have has no FC connectivity… So I’m unable to answer the initial question.. sorry :-(
/RubeckDK
  • June 11, 2026
Hi ​@RubeckDK
I checked and customer have MediaAgent installed on the Aix/Oracle clients and is using IP to connect to DataDomian. This means that DDBoost is working, even though it`s not supported, right?
They are working on the SAN Zonning, and we should be able to test it soon.
Tks!
FT
