Aux copy and data verification failing to pipeline module setting
  • Feb 4, 2025 2:24 AM UTC
  • 54 views
Hi Experts,
anyone seen this error before on data verification task I run after aux copy failed to read chunk from Storeonce disk to be copied to another storeonce catalyst stores. I have tried to look for any pipeline module size settings but not avaliable in any of the MA .
The commvault version is 11.32.54
snipet from CVJobReplicatorODS logs below
14028 4768  01/31 20:46:01 826791 [DM_CHUNK   ] Got new Chunk Info. ChunkId [604744], CommcellId [2], CopyId[50], VolumeId [7263], FileNumber [1], NumberOfArchFiles [1]
14028 4768  01/31 20:46:01 826791 1298171-# [DM_BASE    ] Opening the Chunk =604744, ArchFileId = 265072, FileMarker=1, ArchFilePhysSizeInChunk=533454 VolId=7263
14028 4768  01/31 20:46:01 826791 OpenChunkSpecific(993) - [HWSI_DM] Opening chunk [604744], archfile [265072]. ShouldRehydrateLinks() [true]. m_JobType [106]. m_DestDMType [1].
14028 4768  01/31 20:46:01 826791 [Reader_1] Successfully opened the archive files on the media...going to read data.
14028 4768  01/31 20:46:02 826791 1298171-# [DM_BASE    ] Read [0] bytes while expecting to read [1125] bytes.
14028 4768  01/31 20:46:02 826791 1298171-# [DM_BASE    ] Error handler: Setting JPR for [errorType - 1] [Error-code - 30018] [Error-module - 218104070] [Event-ID - 1040187862] [Handler type - 218104063]
14028 4768  01/31 20:46:02 826791 1298171-# [DM_BASE    ] Job pending reason already been set. ignorring JPR
14028 4768  01/31 20:46:02 826791 [Reader_1] Failed to read data from the source media. Pipeline module specified data whose size is greater than the supported size.
  • Feb 4, 2025 7:17 AM UTC
Hi ​@harism,
We need to check the other media agent logs to understand the issue with the aux copy job and data verification job, would request you to contact the support we will check .
Karthik
