Aux Copy failed
  • Aug 23, 2023 12:56 PM UTC
  • 581 views
Hello All
I have an error with the auxiliary copy
Failed to Copy or verify Chunk [29532431] in media [CV_MAGNETIC], Storage Policy [New-MA2-FS-Backup-Retention-30D-30C-DDB], Copy [Primary], Host [TE-CV-MA-04.efinance.com.eg], Path [F:\YTIUSF_02.16.2021_12.37\CV_MAGNETIC\V_1046223], File Number [19], Backup Jobs []. Please check if all the disk library mount paths in the dedup storage policy copy are properly configured to read from the MediaAgent. Please check if all the disk library mount paths in the dedup storage policy copy are properly configured to read from the MediaAgent.
Rajiv
  • Aug 24, 2023 7:59 AM UTC
Hello @Ayman_Seyam
Is it failing for a specific job id or for whole SP [New-MA2-FS-Backup-Retention-30D-30C-DDB] ?
The MA used in the primary copy should be able to communicate with MA used for AUX copy. Could you please confirm if both the MA’s are able to cvping each other and normal communication on the network is working fine for them?
Also, on the source MA, [F:\YTIUSF_02.16.2021_12.37\CV_MAGNETIC\V_1046223] is this path available and accessible?
Best,
Rajiv Singal
