auxiliary copy jobs problems
  • Jul 29, 2023 5:51 AM UTC
  • 151 views
We have some auxiliary copy jobs configured that run just once a week copyng only the full backp-us to tape
All seems working ok but be received this alarm attached and to be honest,we don't really fully understand it…
Can you kindly tell us why do you consider thta we have this behavior
Thank you
dude
Forum|alt.badge.img+20
  • Community All Star
  • Jul 30, 2023 1:35 AM UTC
Basically it is saying that, you have jobs that have NOT been copied to tape. Right click the Auxiliary Copy SP_VM_CAT_21D3_RO_SLA and scroll over the jobs and there should be jobs showing TO BE COPIED
Run the AUX Copy manually so that those jobs are transferred over to tape. If you have trouble locating those jobs you can use the report
https://documentation.commvault.com/2022e/essential/38030_aux_copy_fallen_behind_storage_policies.html
If you dont actually need those jobs moved to tape, simple right click and select do not copy.
  • Jul 31, 2023 9:27 AM UTC
I know the status to be copied but last weekend this status was not present
Seems that in this morning there are indeed jobs that need to be copied
The problem can be more complex because our storage policy has some clients that make FULL once a month and once a week
Because of this,we created 2 aux copy configuration under the storage policy(storage policy config JPG) but even if we use the option "prevent multiple copies of job across selective copies enabled” on the storage policy,seems that some jobs are copied under the wrong aux copy policy
I mean that under secondary_weekly we have also jobs that make backup once a month but  and are in the state to be copied
Not sure how to separate this part more correctly lets say because seems that also secondary_monthly is picking up jobs that make once a week backup
Should we use different storage policies for the monthly backups and weekly backups ?
