auxiliary copy to tape
  • September 1, 2025
  • 82 views
Good morning, I have a library with two drives, and I need the copy to use only one drive, leaving another drive free for another copy. As of today, when a copy is launched, it uses all available drives, and the second copy is put on hold. I saw that the copy is configured with 100 streams. Should I lower that to 1? Could you guide me so that each copy launched to tape uses only one available drive.
Onno van den Berg
Forum|alt.badge.img+24
  • September 1, 2025
Good morning. Looking at the documentation, I don't see the same thing reflected in the console. Should I change the streams in the schedule policy and leave it at 1?
Onno van den Berg
Are you looking in the legacy Commcell console? Because this is where you should look in this example. Which version are you running?
