Backup export on tape
  • Feb 8, 2024 1:36 PM UTC
  • 82 views
Forum|alt.badge.img+9
I have SAP for Oracle backup on single tape, I need to keep it for years. What will happen if I export this tape and delete all related objects in Commvault (Job and storage policy). Will it be possible to load tape back to tape library and import/restore backup form this tape?
Best answer by Damian Andre
You can do a catalog and merge to bring data back in from a tape where data has aged or you deleted the client/storage policy etc. However, I’d highly recommend just leaving those objects there and hiding them rather than removing them and restoring them later.
https://documentation.commvault.com/2023e/expert/recovering_aged_data_getting_started.html
  • Feb 8, 2024 7:27 PM UTC
  • Feb 9, 2024 10:58 AM UTC
If this is a ‘SAP for Oracle’ agent, you might want to be careful here!
I believe that you can only ‘File System’ and VmWare is supported.
This comes from wanting to do a catalog with a tape that had an Oracle DB, wasn’t supported!
