Client-Side deduplication with HPE Store once
  • Oct 28, 2026 2:31 PM UTC
  • 32 views
Hi All,
When implementing the solution with HPE StoreOnce, the best practice is to enable deduplication at the hardware level rather than on the Commvault side. We agree with this approach and have not created a Deduplication Database (DDB) in Commvault.
We also noticed a recommendation in the Commvault documentation to disable deduplication on the Commvault side.Does this mean that, when associating File System and VMware clients with the HPE StoreOnce storage target, we should disable both deduplication and compression at the client level and on the VMware subclients as well? This requirement is not explicitly mentioned in the documentation we reviewed.
Support for HPE StoreOnce Catalyst Storage
Best Practices for HPE StoreOnce Catalyst Library
  • Oct 28, 2026 5:00 PM UTC
  • Do not enable compression, encryption, or deduplication in the Commvault software. These processes will severely impact StoreOnce deduplication.
So when defining a HPE Catalyst library, you will associate a VSA or FS subclient with a plan. In 11.44 you can now disable compression at the storage level, in earlier version you have to do that at the primary copy level for each plan/storage policy or at the subclient level.
Plan will be linked with HPE Catalyst library and you can disable compression on the plan in the primary copy or at the storage level in 11.44. At the subclient level you can also disable the compression but it is easier if you do that at each plan you define with a HPE Catalyst library or at the storage level for each Store you define instead per each subclient. Dedupe setting at the subclient level does not affect if the storage is not using CommVault deduplication like with StoreOnce, I think when you define an HPE Catalyst library you cannot select the Commvault dedupe feature:
  • Nov 18, 2026 5:18 PM UTC
Hi ​@SrinivasRao,
One thing I would add is to look at the entire copy path, rather than changing the setting on every VSA/FS subclient.
For the primary copy targeting HPE StoreOnce Catalyst, StoreOnce handles the data reduction. But if that Catalyst copy later becomes the source for another disk/cloud copy, review the destination copy independently, as Commvault does not necessarily disable deduplication, compression, and encryption automatically when the source is disk storage.
There is also a storage-capacity consideration: the HPE StoreOnce Catalyst Storage support documentation notes that an auxiliary copy from a StoreOnce primary copy to disk/cloud can result in a larger data size because the StoreOnce primary copy is uncompressed. [documentat...mvault.com]
So rather than changing each subclient individually, I would validate Primary Copy → Catalyst → any Secondary/Auxiliary Copy as a complete data path.
