Combined Tiers - Azure
  • January 19, 2022
  • 77 views
YYZ
Challenger
Does the use of combined Tiers in Azure ‘imply / force’ the use of a Media Agent running in Azure
(Assume the Data in Azure would be 300TB)
Best answer by Mike Struening
I would definitely suggest having an MA in Azure alongside the data itself.  It makes things easier when possibly dealing with egress costs to a local MA (aside from the normal use on restores, etc.).
YYZ
Challenger
  • Challenger
  • January 19, 2022
Mike, Many many thanks.
That was the ‘factor’ I hadn't figured in
A Media Agent VM in Azure close to the data would be important (with CommVault controlling the power on/off state of that MA)
Thank you again
Any time!!!
