COMMSERVE DR TAPE
  • August 16, 2022
  • 191 views
Hi team,
i would like to desactivate Commserve DR to tape (Version 11.28.10)
Try to delete policie but have an error “ Manual deletion of jobs from a worm storage policy is not allowed”
thanks for help.
Regards
Best answer by Collin Harper
Hello @virgil
Since the tape copy is a WORM copy you will need to open a case with Support and fill out a request form to have WORM removed. Since WORM is for compliance and its purpose is to prevent the data from being modified, we need to go through our Legal Team for an authorization code to get WORM removed.
If you submit a ticket we will provide the request form and we can send the request to Legal for an auth code.
Thank you.
Collin
  • August 16, 2022
Hello @virgil
Thank you.
Collin
