Commvault and Isilon
  • Jan 16, 2025 7:07 AM UTC
  • 122 views
Can anyone advise on best configuration for using Isilon as back end storage for on prem Commvault. Would you use Linux or Windows Media Agents ?
RubeckDK
Explorer
  • Jan 16, 2025 9:21 AM UTC
Hi…
We have a few of these Isllon clusters (20+ nodes) running… providing SMB shares for Windows MAs in grids…. Works well… very stable. They’re backed by CVLT DDBs ofc and performs well during backups… but restores can be a pain depending on model being used.
As I remember sparse file support isn’t enabled by default, so you have to enable this by using the “isi smb settings share modify --sparse-file=True”  command..
/Rubeck
  • Jan 16, 2025 9:30 AM UTC
thank you for your reply. Are you using 25g ports and if so what type of throughput are you getting for backups. Do you have a mixture of VM and Agent based backups. We have many many SQL servers so the throughput of these is my biggest concern.
  • Jan 16, 2025 1:37 PM UTC
Has anyone got any experience of using Linux Media Agents with Isilon being the target storage ?
