Configure two tape libraries in one storage policy
  • March 19, 2021
  • 185 views
Hi to All,
Can I configure two tape libraries in one storage policy, in order to balance the load or in case of failure?
Best answer by sbhatia
You can add two data paths under a single Storage Policy Copy if this is the answer you are looking into. You can then enable Round robin.
sbhatia
  • March 19, 2021
