Configuring Worm Storage Lock on Azure Storage
  • October 7, 2024
  • 260 views
In Commvault’s document for configuring WORM Storage Lock for Microsoft Azure Storage ( Configuring WORM Storage Lock (commvault.com) )says:
but the links to Microsoft articles on Blob versioning and optimizing costs are pretty general pages coverage all lifecycle rules. Could someone provide an example lifecycle rule in Microsoft terms? eg the Microsoft lifecycle wizard gives the options like Delete the blob if it hasn’t been modified in x days etc. it doesn’t seem to use terms like Commvault says “clean up previous versions”
thanks!
Best answer by Nikhil Gupta
Hi @KelvinF ,
Hope below helps
Storage Accounts > Data Managment > Lifecycle Managment
Details Page:
Sections Add a rule
Rule Scope [Apply rule to all blobs in your storage account]
Blob Type [Block Blobs]
Blob SubType [Versions]
Click > Next
Versions Page:
Created
    More than (days ago) [<Value should be Commvault WORM lock days (retention + DDB sealing frequency)>]
Then [Delete the blob version]
Optional: I would personally add a safety net to value on More than (days ago) like 10 days may be.
@Nikhil Gupta can someone check this?
Forum|alt.badge.img+2
  • October 8, 2024
Hi @KelvinF ,
Hope below helps
Details Page:
Sections Add a rule
Click > Next
Versions Page:
Created
  • October 8, 2024
thanks, that is what i was looking for.
Kelvin
