Hi all, I’m planning on replacing our MA server, and I just needed a sanity check on the Replace Media Agent App and Move Mount Point processes. The old MA has a Disk Library with 7 mounth paths, most of which are iSCSI LUNs from a couple different arrays. The new MA will have much more direct attached storage, so I’m plannin on just 2 mount points.
If I run the Replace Meda Agent App process, and let it run the Move Mount Point process, am I able to consolidate the old mount paths down to 2 during this process, and specify the destination of each of the source MP’s?
I assumed that I can because the Move Mount Path function in the Commcell console offers me the option to move it to an existing device, however the documentation says:
The move mount path operation overwrites the destination mount path. Therefore, ensure that the destination mount path is an empty folder.
Can anyone offer any clafification?
