Content Indexing (v2) for Exchange Mailbox not needed any more - how to delete Index contents?
  • Feb 4, 2025 11:22 AM UTC
  • 97 views
Hello
We are using Exchange Mailbox archiving with +10 year retention. For a couple of years we have been using Content Indexing for these jobs, but it’s not needed any more. We have disabled CI and it’s valid for next archiving jobs, but how to clean up previous Content Indexing entries (without deleting archiving jobs)?
We would like just to free up space on CI disks as it’s not required any more.
As far as I know this procedure - https://documentation.commvault.com/11.20/deleting_content_index_of_specific_backup_job.html - points to Indexing V1 and we don’t have such option in our job history menu.
Kind regards,
Maciek
Mohamed Ramadan
Explorer
hello ​@Maciek
there is a way to delete the Index folder manually, but it might be a bit risky as it could impact the search engine. If you prefer, you can retain the index in accordance with the data retention policy to ensure it's preserved.
https://documentation.commvault.com/2024e/expert/pruning_content_index_along_with_data.html
Mohamed Ramadan
Data Protection Specialist
  • Certified Expert
  • Feb 4, 2025 12:11 PM UTC
Hello
Your post points to “Pruning the content indexes along with the data is the default behavior.”. We would like to keep arching jobs while pruning/deleting only Search Engine entries related to these jobs.
Mohamed Ramadan
Explorer
Hello
Ok set the retention period for the indexed data or you can either delete the content in the Index directory manually
This way, the content indexes will be pruned before the data is pruned
Mohamed Ramadan
  • Certified Expert
  • Feb 5, 2025 8:17 AM UTC
Hello
Mohamed Ramadan
Just deleting content of Search Engine directory? Not gentle/sophisticated way ;) Maybe something more official & graceful?
Mohamed Ramadan
Explorer
Hello
Mohamed Ramadan
dont worry ​@Maciek we do this alot for many CSTs during hardware refreshes for the search engine servers.
after removing the old search engine node from the CommCell, we simply delete it manually.
note: please ensure that content indexing is disabled first.
Mohamed Ramadan
  • Certified Expert
  • Feb 10, 2025 8:17 AM UTC
You assumed Ive deleted Search Engine node from the console what is wrong. This Search Engine is used and will be used for o365. We would like to delete only Exchange mailbox part of this Search Engine
