Create Credential API call fails
  • Oct 21, 2024 7:03 PM UTC
  • 150 views
I am trying to make an API call to create a credential but is failing with error “Request body is empty, or format is invalid.”
I did not modify anything except the endpoint and Token. I am not sure what mistake I am doing here.
documentation referred # https://api.commvault.com/docs/SP32/api/cv/OpenAPI3/create-credential/
import requests
import json
url = "https://commvault.newblr.com/commandcenter/api/V4/Credential"
payload = json.dumps({
  "accountType": "CLOUD_ACCOUNT",
  "vendorType": "HITACHI_VANTARA_HCP_S3",
  "name": "HCPBucketuser01",
  "userAccount": "Y3ZidWNrZXQ",
  "password": "dc06698f0e2e75751545455899adccc3",
  "description": "API test",
  "security": {
    "owner": {
      "user": {
        "id": 0,
        "name": ""
      "userGroup": {
        "id": 0,
        "name": ""
    "associations": [
        "user": {
          "id": 0,
          "name": ""
        "userGroup": {
          "id": 0,
          "name": ""
        "permissions": {
          "permissionId": 0,
          "permissionName": "",
          "categoryId": 0,
          "categoryName": "",
          "type": "ALL_CATEGORIES",
          "exclude": True
        "isCreatorAssociation": True
headers = {
  'Content-Type': 'application/json',
  'Accept': 'application/json',
  'Authtoken': 'QSDK ******'
response = requests.request("POST", url, headers=headers, data=payload,  verify=False)
print(response.text)
Best answer by Vignesh S
Below are the fields required to create a cloud account credential. you can try with below.
import requests
import json
  "vendorType": "HITACHI_VANTARA_HCP_CLOUD_SCALE_S3",
  "name": "XXXX",
  "accessKeyId": "XXXX",
  "secretAccessKey": "XXXX", //must be in base64 encoded format
  "description": "XXXX"
headers = {
  'Authtoken': 'QSDK XXXX'
response = requests.request("POST", url, headers=headers, data=payload,verify=False)
Mohamed Ramadan
Explorer
hello @Gaurav Shrivastava
i hope you are doing well !
This error means the CV server is not receiving the payload correctly.
Could you please check if the JSON payload matches the structure in the documentation?
I also recommend using a testing tool like postmaan to determine the issue in your code or with the API endpoint itself.
Mohamed Ramadan
Data Protection Specialist
Forum|alt.badge.img+2
  • Oct 22, 2024 2:26 PM UTC
import requests
import json
  "name": "XXXX",
headers = {
Hi All
Thanks for your suggestions. I made API call by commenting few non-mandatory fields.
        "name": credentialName,
        "userAccount": namespaceUser,
        "password": namespacePassword_base64,
        "description": "API Integration",
        "security": {
            "owner": {
               # "user": {
               #     "id": 0,
               #     "name": ""
