Creating a second copy on cloud library
  • Oct 8, 2024 11:20 AM UTC
  • 80 views
Hi
We have primary backups directed to an Azure cloud library - in a storage pool accessed by 2 media agents with deduplication enabled.  I would like to know if its possible to create a second Azure cloud library for copies with deduplication enabled, using the same 2 media agents.  Any recommendations on config appreciated,
Best answer by Jacek Piechucki
Of course, it can be done. New storage pool has to be created, preferably using different volumes /mount points for DDBs, so they do not compete for IOPS/space.
  • Oct 8, 2024 2:26 PM UTC
Thanks, so for instance would we configure it as follows:-(Azure Blob storage)
Storage pool - Cloud Library 1 Region 1 - 2 DDB partitions on MA1 and MA2
Storage pool - Cloud Library 2 Region 1 - 2 DDB partitions on MA1 and MA2,
2 DDB partition mount points on both MA1 and MA2
I’m hoping then to avoid inter-region transport costs if the primary and secondary copies are both hosted in the same region.  We also have Geo redundancy setup in the event of a region failure,  Is that the best way to do it?
Colin
