Data Retention and Storage Policy
  • Jan 9, 2025 9:27 AM UTC
  • 127 views
Hi all,
I need to archive files for 1 year, but I do not have the archive licenses.
My current configuration is as follows:
  • Storage Policy: 1 year, 0 cycles.
  • Incremental backup every day (the first backup was a full backup).
  • A share where files to be saved for 1 year are deposited.
  • If the incremental backup completes successfully, a Unix script deletes files older than 15 days from the share.
Problem:
  • The jobs do not expire after 1 year.
  • Jan 9, 2025 11:40 AM UTC
Check the Data Retention Forecast and Compliance Report, it will advise why a particular job is retained pass its configured retention
https://documentation.commvault.com/2024e/expert/data_retention_forecast_and_compliance_report_overview.html
The report initially indicates:
then subsequently
However, it is still unclear to me why the data does not expire. Are the cycles of the policy set to 0 incorrect? Is it not possible to manage a data expiration after 1 year with an initial full backup and subsequent incrementals ?
Erase4ndReuseMedia
The data is not aging because recoverability rules still apply when using 0 Cycles.
In simple terms, your current Incremental backup is dependent on the preceding Full + Incremental backups for recovery, so the preceding jobs will not be aged until all jobs in the Cycle have met their retention requirement.
You may need to consider performing periodic Full / Synthetic Full backups to close off Cycles.
