DDB Reconstruct Force Library
  • Jan 27, 2025 2:14 PM UTC
  • 95 views
I have a DDB Reconstruct running of a secondary copy that writes on Storage S3, the DDB backup writes on both S3 and CentricStor, i want to restore the DDB from the CentricStor library but it always try to restore from the S3. How can i force the restore from 1 specific library?
This DDB is partitioned and only 1 partition is offline.
João Amaral
Mohamed Ramadan
Explorer
hello ​@jmiamaral
you can try to restore the DB files manually, go to the Media Agent (MA) under the File System section. You'll find a default subclient named "DDB Backup." You can restore the DDB by job ID.
I recommend first changing the DDB path and selecting the "Move config only" checkbox before proceeding.
Mohamed Ramadan
Data Protection Specialist
  • Jan 28, 2025 10:30 AM UTC
Hello ​@Mohamed Ramadan
The problem here is that the reconstruct started for the DDBs of the auxiliary copies but i have another DDB on the same media agent that is online, i cant choose to restore only the DDB of the aux right? Will it not affect the other DDB that is online?
jmiamaral
  • Jan 29, 2025 4:06 PM UTC
Do you know if the data on the auxiliary copy gets deduped if the primary copy has dedup active? With no DDB on the aux copy.
jmiamaral
