DDB Space Reclamation
  • Oct 10, 2024 7:54 AM UTC
  • 104 views
Forum|alt.badge.img+5
Please anyone can help me to resolve this problem, i’m sure all of my mounts paths are online and i can’t find which mount path is offline as it not mentioned from the job itself
Mohamed Ramadan
Explorer
hello @Mohamed Nabil
السلام عليكم
Could you please check the CVMA.log on the Media Agent and the MediaManager.log on the CommServe
Also, the CommCell readiness report would be very helpful.
Mohamed Ramadan
Data Protection Specialist
Hi @Mohamed Nabil
The DDB for which this job is running, can you check under the storage, which mountpaths it is using and see if some mountpath has been marked offline.
