Answer
DDB storage for DR restore only
  • May 24, 2021
  • 148 views
Doing some preparation of our DR environment and wondering, if we intend to only do restores in the DR environment, is SSD still a requirement?
My thoughts were the performance is required to do signature lookups (for writes), but for restores this would not be required.
Best answer by Blaine Williams
You are correct you do not need the DDB for restores.
However as part of your disaster recovery plan you should plan in a backup strategy as dependant on the disaster you do not know how long you will be using the DR system and one recovered. It will become new production protected data which you will need to protect it.
Forum|alt.badge.img+8
